Results 1 to 5 of 5
Thread: Gt 650 won't start or turn over
    Jan 2019
    United States
    I recently bought A GT650 it had been running fine it's been park for about a month I went out to start it the other day everything lights up like normal everything works on it except when I hit the start button it's not even trying to turn over. We put it on the trickle charger thinking that just didn't have enough juice to start even though it had enough juice for everything else. It's been on the trickle charger for 24 hours the light has turned green and yet it won't start any ideas? I'm applying either break the left or the right along with pushing the button I do not have the side stand down.
    Member Thom Davis's Avatar
    Feb 2018
    Northern California
    Those are always difficult to troubleshoot. Side stand switch was an issue in early years, could be a fuse, could be the brake switch, or the ignition switch. PITA
    good luck but be patient, you'll find it.
    Dec 2014
    Seattle, WA
    Do you have EWS! and yellow warning triangle?
    Jul 2016
    Huntington Beach
    How old is the battery, wifeís 13gt had same issue, turned out battery had gone bad, even though it lived on a optimate 4
    3 years and I change motorcycle batteries now
    Member Jetblack528's Avatar
    Feb 2016
    Oregon, Portland area
    Quote Originally Posted by Oklahomascarlet View Post
    I recently had a similar problem with my 2013 scooter. I always keep it connected to a battery tender when parked, but when I went to start it no luck even though the tender showed solid green lights indicating a full charge. Dash lights came up but starter would not turn over at all. I tested the battery with a multimeter and could tell it was not holding a charge. Put in a new battery and it fired right up. It was an original BMW battery with a production date of 09/2012 so Iím not surprised that it failed.
Tags for this Thread
