Results 1 to 6 of 6
Thread: Oil Level
    May 2019
    Grand Rapids, MI
    Oil Level
    Is there a trick to getting the Oil display to work? Manual says that it will show if the oil level is OK as long as:
    • Bike is at operating temp
    • Side-stand is up
    • Bike has idled for at least 10 seconds
    I went for a ride this morning and checked at every stop light it always shows "_ _ _"
    2016 Bronze C 650 GT
    Feb 2019
    Wiesbaden Germany
    Mine works as long as you'e not moving.
    Yes, scooter must be stopped. Here is a pic from the owner's manual:
    2000 BMW K1200RS
    2004 BMW R1100S
    2005 BMW K1200S
    2016 BMW F800GT
    2018 BMW R9T Pure
    2018 BMW C650GT
    Oil level indicator
    The oil level display 1 provides
    information on the oil level in the
    engine. This display can only
    be activated when the vehicle is
    stopped.
    The conditions required for using
    the oil level display are as follows:
    - Engine at normal operating temperature.
    - Engine idling for at least ten seconds.
    - Side stand retracted.
    Displays
    Maxi-Scooter is positioned vertically.
    The displays which may appear
    in positions 1 and 2 mean the
    following:
    OIL OK: oil level correct.
    OIL CHECK: check oil level during
    next refueling stop.
    OIL ---: no measurement possible
    (above-mentioned conditions
    not met).
    2000 BMW K1200RS
    2004 BMW R1100S
    2005 BMW K1200S
    2016 BMW F800GT
    2018 BMW R9T Pure
    2018 BMW C650GT
    May 2019
    Grand Rapids, MI
    Quote Originally Posted by Rodan View Post
    I read that section, but I am not getting a display. I've been stopped at several red lights for well over 10 seconds and no display. I've also sat on bike in garage after a ride and waited while idling - no luck.
    It's not that big of a deal, but it is a hassle to check the oil with the stick. The bike has a few months warranty left - I suppose I could have the dealer look at it.
    May 2019
    Grand Rapids, MI
    I got the"OK" today Was at a red light, but it took about 20 seconds to display.
