Page 4 of 4 FirstFirst ... 234
Results 31 to 40 of 40
Thread: battery charging through accessory connection
  1. #31
    Senior Member JaimeC's Avatar
    Jul 2013
    Hicksville, NY
    They must've changed it in the 2014 model year. Wonder why? Maybe some users left something plugged in and forgot about it, and it drained their battery? It'd have to be in there for a long time though. Like I said, I charge up my phone in there overnight when I'm on a camping trip and always had plenty of power to start the scoot in the morning.
    Jaime A. Cruz
    Nassau Wings Motorcycle Club
    http://www.nassauwings.org
    http://www.freddysrun.org
  2. #32
    Senior Member
    Jun 2014
    Lewiston, Idaho
    Quote Originally Posted by JaimeC View Post
    Could very well be. Just wish the Operators Manual would have mentioned it. I went to connect mine up to a Battery Tender a couple of weeks ago and the port was dead on my 2015 GT also. I tested the adapter on another vehicle and it worked so I then tested my XM radio on the scooter to see if it would power that. Nothing (with key off). I went to the dealer and talked to them about it. The suggested turning on the key, inserting the adapter for the Battery Tender, then turning off the key. The Battery Tender then recognized that it was connected but when I turned the key to the off position, the LED running lights and the instrument panel display both remained on.
    The Service Manager had installed a new air temp sensor a couple of weeks prior to this and he told me that he was sure he'd seen a charging connector up under the cowling. Thankfully it was there. I was unable to buy the scooter from my local dealer and so had to buy at another shop north of where I live. They must have installed the charger wire. That was kind of a surprise to me as I had ordered the bike and took delivery of it 3 days after it arrived at the dealer so it was never floored. At any rate, I can vouch that by 2015 anyway the accessory port is not hot when the key is off.
    Praise CanBus!
  3. #33
    Mar 2016
    Rockland County, NY
    Just don't try to jump start the bike through that port
  4. #34
    Senior Member SteveADV's Avatar
    Sep 2013
    Chagrin Falls,Ohio
    Quote Originally Posted by Tony View Post
    Ha...Excellent.
  5. #35
    Dec 2013
    Philippines
    Get an Optimate 6. Connect the charging cable directly to the battery. Connect when at home to charge the battery.
    Install a PDM60 so that you can program what appliances should only turn on when ignition is on. Leaving an always hot accessory port could open you up to people who will plug in and drain your battery (eg charging their phone).
  6. #36
    Junior Member
    Oct 2018
    Ohio
    Port is HOT in one direction and COLD in the other direction?
    I think the Port is HOT in one direction and COLD in the other direction!
    I have a 2015 C650 GT. When I try trickle charge using the cigarette port in the cubby box, and I plug it in with the ignition OFF, it turns on all the lights like it's in accessory position and the charger seems to be blinking green, so I assume it's trickle charging.
    But on the other hand, if I take my cell phone charger and plug it into the cigarette port with the bike OFF my phone will not charge. But if I turn the bike ON then the phone will charge.
    This may make sense, as when I'm trickle charging through the cigarette port the power is going thru the charger, then, through the port into the battery. But when I'm trying to charge my cell phone, the power is coming from the bikes battery through the port into the phone. I'm no electrical genius, but these cases do seem "charging opposite" and could account for the ON and OFF situations.
    I assume it is in my garage trickle charging right now, but I hope that the trickle charge is greater than the charge being drained by the lighting that's being turned on when I plug in the charger.
    Any thoughts?
  7. #37
    Junior Member
    Oct 2018
    Ohio
    This is what I experienced... but maybe the ON / OFF cycle you described is the secret code I inadvertently activated???
  8. #38
    Junior Member
    Dec 2014
    Seattle, WA
    Some chargers (like my old BMW charger) and maybe some newer ones like the optimate can communicate with the computer which is never really off to open the port for charging the battery. That outlet normally will stay powered up for a few minutes after shutting the scooter off, and I have heard but never actually seen that some devices can keep the port powered indefinitely. Most people will connect a pigtail for the charger directly to the battery which may or may not be necessary depending upon the charger and accessories you own. The outlet has a current carrying capacity of 5A which is plenty for a small battery charger/maintainer, or to run a gps or charge a cell phone. It's not enough to reliably power a heated jacket or an air compressor.
    You might already know this but the scooter (at least originally) has an AGM battery which requires different charging parameters than a lead-acid or gel-cell batter. To get the most out of your battery make sure you match the charger/mode to the battery type. Also, those little 1.5-2 amp trickle chargers are for maintaining a charge and can't usually charge a really dead battery. Same with your bike (or car's) alternator. Although it's hard on your battery to discharge down to 8V or so - it may be still ok even if your trickle charger doesn't seem to work. Have it tested, and try and hit it with a higher capacity charger before you give up on it.
  9. #39
    Member Thom Davis's Avatar
    Feb 2018
    Northern California
    If you do have to replace, I recommend a Li-ion. Then you don't have to (and should not) use a trickle charger or battery tender (those are bad for li-ion batteries). Li-ion are less than half the weight and take up half the space so you do have to stuff something in to keep the battery in place. But its worth the slightly higher cost ($100 at amazon).
  10. #40
    Junior Member
    Oct 2018
    Ohio
    Trickle Charge via Accessory Port and Install Lead from Battery in Cubby
    Trickle Charge via Accessory Port- No Go I have a 2015 C650 GT. When I try trickle charge using the accessory port in the cubby box my charger indicates no connection. If I turn it on it connects but all the accessory light, etc. are on. I tried this and believe it or not the battery that used to try to turn over ended up just clicking. So maybe the trickle charge puts out less than what the accessories take away. If I'm missing something here with trickle charging through the accessory port , please let me know.
    Install Lead from Battery in Cubby I'm just going to install a separate lead from the battery. If you're not going to run a bunch of stuff off this… the cleanest way I can think of is just open the cubby door and you can drill about a 5/8 inch hole through the plastic side of the cubby and just run the connection right inside your cubby. No junkie stuff hanging off the bike.
