Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: battery charging through accessory connection
    Senior Member
    Feb 2015
    Toronto, Canada
    Please excuse what is probably a bit of a rookie/newbie question. Can you charge a battery through the standard accessory port/socket if you have made it live instead of switched? Just trying to think of the easiest way to go without removing panels etc.
    Senior Member
    May 2014
    wilmington vermont
    You can charge the battery through the outlet in the left hand compartment you just need the right adapter for the outlet and plug in your battery tender
    AKA Bill Steele
    Senior Member
    Feb 2014
    Don't go bigger than a trickle charger, or you could make a crispy wire!!
    Senior Member
    Feb 2015
    Toronto, Canada
    Quote Originally Posted by wsteele View Post
    I am correct though am I not in saying you have to make it a live rather than switched assuming it's to be charged without ignition on?
    Senior Member
    Feb 2014
    charging
    Quote Originally Posted by Colin J Monteith View Post
    I don't remember if that outlet is switched, and I don't use it. I ran a separate fused and manually switched circuit to my handle bars. This circuit powers my AM FM radio, GPS, heated clothing, and provides a path for charging the battery.
    Senior Member JaimeC's Avatar
    Jul 2013
    Hicksville, NY
    That outlet is NOT switched, it's always "hot." I know this because I leave my phone in there to charge up overnight while I'm sleeping in the tent and it works.
    However, I had a second socket installed that utilizes the standard BMW plug on the handlebar housing. That way I can plug in an electric vest in the winter. That socket is also not switched, so I use that one when I plug in the battery tender.
    Jaime A. Cruz
    Nassau Wings Motorcycle Club
    http://www.nassauwings.org
    http://www.freddysrun.org
    Senior Member yellasei's Avatar
    Dec 2013
    merseyside uk
    none of the power outlets on the scoots run through canbus switching, they are always live.
    2012 G650 GS
    2007 vespa GTV125
    Senior Member
    Feb 2015
    Toronto, Canada
    Does the scoot canbus have any spare connections?
    Aug 2014
    Napa, California
    I've been wondering if dealers install the battery tender accessory for their own purposes here in Cali or what? My friend got a GT from A&S in California. The battery tender accessory end was pulled through the left side and sort of hanging there. They pushed it back through at his request so it is accessible above the front tire by the "T" looking bracket. I was bored and looking up with a flashlight to the same area under the front faring of my own bike and ..... there was the same connector. It looks like the same battery tender connector and its zip tied on the side of the "T" looking bracket/bar.
    I'm gonna call the dealer but it made me wonder whether it is for something else or is it just the dealer installed it to keep the battery charged during the loooooonnnnng showroom time.
    Does anyone else have this accessory end in the same area?
    Senior Member
    Feb 2015
    Toronto, Canada
    It's probably cheaper to just install for showroom bikes and leave on. I doubt the cost is any more than $5 and in their world it would cost that at least to remove again.
