BMW C650GT Cam Chain Tensioner replacement instructions and parts
antidot
Barrie
Hello everyone,
Been searching the internet for days now, and can't find comprehensive information on the cam chain tensioner replacement. I'm a part time motorcycle mechanic, and I'm trying to help a friend with his 2016 C650GT. I've ordered a manual cam chain tensioner from Ebay, but looking at various posts, it's apparent the oil feed line to the hydraulic tensioner must be capped off, or somehow disabled.
I also need help with the tupperware removal. I've got the 2019 RSD BWM DVD, I can navigate through it, however a little bit more straight forward video or pdf with instructions would be of more help to me.
Can somebody explain or post a link where I can get information of disabling the oil line (parts I may need for that), and in general a more comprehensive guideline to do the job?
Thank you in advance.
Prevailing wisdom in this forum is the hydraulic tensioner with the oil feed line is the preferred solution. That's what is installed in 2016+ models (not ALL 2016's since the change was made in the middle of that model year). A swap to a mechanical tensioner seems like you are regressing to the original design, which failed not infrequently. BMW consistently stepped up and replaced engines and sometimes entire bikes, but that coverage is long gone.
As for tupperware, my rule is "work from the top down." Open the gas cap lid and pinch in the hinges to remove that. From there work toward the ground, piece by piece, until you're at the footboard and below. Reverse to reinstall (from the ground up).
Thanks for getting back to me, I appreciate it. The job is done, wasn't that hard. I replaced the mechanical cam chain tensioner (spring loaded) with a manual cam chain tensioner (bolt and lock nut). Works like a charm. I've done $hitload of them on Yamahas and Hondas, same design, same failure.
Anyhow, no more rattling when cold, and no chance for the chain to jump! I've created a .pdf on how to remove the side panels, foot boards (tupperware) etc. to get to the cam chain tensioner.
Cheers
PS: I was under the impression that the cam chain tensioner in the bike was already a hydraulic type, hence my question about capping off the feeder oil hose/line.
I replaced mine and it was a bit touchy to install, but the plastic removal was by far the biggest deal in the whole procedure. If you are doing the conversion, I don't see the value at this point. It is costly and a quite complicated. The part came from a BMW car dealer, as BMW no longer offers this part for the bike. But is is exactly the same and is used on the fuel extender engine in the i3 electric car.... never understood why you would put a gas engine in an electric car other than the fact that electric cars anit worth a darn. It's very doable job and gives you some time to check on other aspects of the bike while replacing it. Such as, oil level, spark plugs, filters and coolant. I also took time to clean the areas under the plastic and to check for oil leaks.... still checking. It should last long enough and just wash, rinse and repeat again if needed. Good luck!
Hello, thanks for providing good info. Do you mind letting me know how the scooter is acting with the mechanical tensioner and how did you adjust to the correct tension. I bought the same one and I am planning to replace it at next season’s start (I’m not so mechanically inclined, but I did some work on it myself already).
the one I installed was from BMW and not adjustable, but spring loaded. there are a lot of videos online for the adjustable cam chain tensioner. all the sport bike guys use them now instead. I was a be scared to use one.. Replacing the tensioner is not a big deal, just takes a long time to remove the panels. you only need to do the side with the tensioner not all the panels. It takes some dexterity and a little force to get in out and back in but still very doable even if you are not so inclined. always good to do some other work when you have the plastics removed. make sure to keep all the screws in one place there are a lot! Good luck and just have fun with it.
Hi guys. First post and it's about .. . yup... the early model tensioner. First off my background. 5-time ASE Master Certified Mechanic, 35 years in the business, 10 years fixing Avionics in the Marines, a ton of certs and training through the years, and experience with way too many 'warranty' claims. So, that little noise in my scooters engine, that I'd traced to the Right side and thought it was the Variator weights because it went away after warm-up...yeah, it reached out and bit me about 10 days ago. Fortunately when it got REALLY loud, from the chain slapping around, I was 500 yards from my driveway, so I just coasted in at idle and waited to see what would happen. It was still running on both cylinders, then stumbled and lost power. I did NOT try to re-crank, though. When engines make bad noises then die, it's a really bad idea to try to restart after stall. So after I got it settled in the carport, I came on line and found THIS wonderful Forum (VERY much appreciate what you've been doing here) It took a few days to get over the depression of my scooter engine trying to eat itself, then I got to tearing things apart. I swear BMW intentionally, makes it difficult to work on this bike. But, I got the side cover off and the upper chain guide and chain are just slack. I can flop them up and down about 3/4" with ease. Yup, not good at all. I pull out the mechanical tensioner and disassemble, and the spring is broken. Okay, that sux so I took a picture. The bike has 11,000 miles and I was going to do the 12K service in a few months anyway, so I went ahead and started it now. Pulled the radiator and then got the plugs out and snaked my bore scope into each cylinder. Yup, small 'eyebrow' marks on the intake side of each piston. Sigh...Still, I re-timed the cams and manually locked the cam chain guide in place so I could spin it over to check compression, but all that did was prove that ANY sort of contact between pistons and valves is a BAD THING. Zero compression. Off came the head, and all 4 intakes need to be replaced. Pretty typical I'm guessing.
So...NOW I go to my local BMW/Ducati/MV Agusta dealer, carrying my bad tensioner and with all the Recall information on these tensioners. And then things REALLY start to go down hill.
First off, no one seems to be able to find the Recall. My Scooter was built in January-2014. The range of dates for the recall is August 12, 2022 to February 18, 2014. Mine was built in January 2014. All the engine parts were cast in December or January, the date on the Tensioner is January 25, 2014 (so it's almost a month inside the deadline) so the engine was put together in January, 2014. You'd think this is simple, right? But NO, not with BMW. First, they can't match my bike to the Recall for some reason, even though the recall stipulates that date range. Secondly, they try the 'but it was already replaced' because of the date of the tensioner (isn't that supposed to be an upgrade to a Hydraulic piece??) And since they are so befuddled by their lack of ability to research this they give me the number to BMW NA. BMW NA turns out to be just as befuddled and inept, so I call NHTSA, where I finally get ahold of someone who can think and breath at the same time, with their mouth closed even. An hour on the phone with this nice young man, and we go through all the things associated with this little issue, and I get ALL the information, as well as going through the process of initiating a complaint.
Then I start reading all the PDF's associated with the recall, especially the last one where BMW finally tells us WHY these things fail. Something about a 'burr' on a stamped part, which I find to be ludicrous. It's just so ambivalent and imprecise. What burr, on which part of the assembly? As you can see from the attached pic, the spring failed at the top, where it engages the winder feed, directly in line with the engagement slot. What in the world could make it fail right there? I did a close up examination of the surfaces of the stamped shaft, and right next to the groove's end is a small high spot, probably less than a millimeter but you can feel it when rubbing it. The other side does not have it. I lined things up and the break in the spring corresponds to that point exactly. People will say.. but it's just a little high spot...yeah, one that will touch the spring after tension is put on it by twisting it tighter against the internal barrel of the tensioner. Which means that after it's all assembled and put into the engine, under tension, the spring now rides on that small high spot, concentrating all the stress, vibrations, and harmonics on that one spot, rather than spreading it across the entirety of the spring and barrel. Over time, that work hardens the spring, the constant micro-hammering of vibration changing the metallurgy of that one spot and weakening it, until it finally fails.
So, now I have a pretty good idea what the cause of the failure is. I need more information from the community if I can get it so I can push this forward with the NHTSA. But a few questions as well. Aren't all C650's supposed to be upgraded to Hydraulic tensioners? It seems so according to the Recall. Secondly, if the 2nd generation Mechanical tensioners are failing almost as badly as the 1st design, doesn't that make BMW still liable, since their 'fix' obviously is NOT.
If anyone took the time to disassemble their failed tensioner and make pics of the internals I'd appreciate them forwarding or posting them. Finding a consistent failure point would be a big help. With enough evidence maybe we can all get refunds or future PROPER repairs for this issue from BMW. I'm certainly going to be pushing it. $450 worth of valves plus a head gasket and about 15-20 hours of time wrestling with the BMW cursed design of this scooter kind of requires me to get very much in some corporate drones face and rectify their problems.
As for my own bike? I'm probably going to get the hydraulic unit, but not from my local dealer (They have a tendency to lie to me), then have a local Hydraulic line shop make a line for it. I'll need the 1-way valve as well, but I should be able to get out of this for less than $300 to replace the mechanical tensioner. I'm pretty sure the Dealer is just going to dig in it's heels and it will turn into a head butting match. A set of used valves is coming from MSP, and I have a source for the head gasket.
If you've made it this far.. thanks for reading. Any inputs to get more information for that NHTSA complaint would be appreciated.
Sorry to hear about your problems. Mine, as I just posted on your other thread, displayed the same symptoms as yours did, it sounds like: quiet on cold startup, then a faint rattle for mabe 5-10 minutes, that then went away rest of the trip. This is with about 2K miles on this 2016 Sport. Took it to dealer who replaced under warranty. However, with another mechanical tensioner, not the hydraulic one. So it seems the recall was NOT to upgrade to hydraulic, OR my Long Beach BMW dealer did not perform the recall as they should have, OR maybe as mine was a 2016, it had the 'improved' mechanical tensioner and BMW said, no need to go hydraulic on those.
Then at around 10K miles, I start hearing an unusual noise again, this time when engine had warmed up. Took it to dealer for a brake hose recall and asked them to check the engine noise. "Nothing unusual" was the report back. Not trusting their competence, I ordered a new tensioner, along with the special tool to fix the flywheel in place, and replaced the tensioner myself. Sure enough, the old one was 'frozen': no spring action whatsoever.
So far so good on the 3rd tensioner. I have a good ear for mechanical sounds (although not a mechanic, I'm a white collar accountant!) so trust myself to spot it starting to go again, although that's a bit of a high-stakes gamble of course. Maybe one day I will go through the extra trouble of converting to hydraulic.
Cheers
Mine had the exact symptoms as your first failure. Starts fine, bit of noise for 5- 10 minutes then quiet, then finally catastrophic failure. if you still have the 2nd tensioner, you might want to take it apart and see if it mirrors what mine did. As for being 'frozen', that could be due to the broken part jamming the rotating barrel in some way and preventing movement. Still, it would be better to take a look and find out what the internal failure was. I 'fixed' my tensioner, sine the Dealer and BMW-NA were making it so difficult to get a resolution. I cut off 1/8 of the rotating barrel at the top slotted area, took a 6mm flanged bolt and cut the head with a dremel tool so that all but the flanged piece fits into the slot in the winder, then ground down the threaded area for about 100 below the head. That way when it is screwed into the threaded area from BELOW, it just floats on the threads. Then I reinserted all the parts into the tensioner, threaded a lock-nut onto the exposed bolt threads and a locking nut to the end of that. Now, I can lock the tensioner in place after spinning for desired tension of the chain follower, and lock it so it will not move. If the spring breaks it is locked so it can't unwind and cause lack of tension of the chain, and if I notice any noise I can 'adjust' the tension as desired, plus when I loosen the lock nut I'll be able to tell if the spring is still working properly by checking for tension. Took a half hour to make the modification, and it will never come loose again.
My tensioner worked for over 50k km and was still running grat, but I decided to replace it. I bought Kymco tensioner (part number 14550-LKF5-E00), which is the same thing as BMW, but for half price.
Do you have any pictures of it, especially of the production date on the side?
Yes, that's what I mean. Too bad about not being able to upload a picture. Would be nice to have photographs to submit into my complaint.
Désolé d'entendre parler de vos problèmes. Le mien, comme je viens de le poster sur votre autre fil, présentait les mêmes symptômes que le vôtre, cela ressemble à : un silence au démarrage à froid, puis un léger cliquetis pendant peut-être 5 à 10 minutes, qui a ensuite disparu pendant le reste du voyage. C'est avec environ 2 000 milles sur ce Sport 2016. Je l'ai amené chez le concessionnaire qui l'a remplacé sous garantie. Cependant, avec un autre tendeur mécanique, pas celui hydraulique. Il semble donc que le rappel n'était PAS pour passer à l'hydraulique, OU mon concessionnaire BMW de Long Beach n'a pas effectué le rappel comme il aurait dû le faire, OU peut-être que comme le mien était un 2016, il avait le tendeur mécanique « amélioré » et BMW a dit, pas besoin de passer à l'hydraulique sur ceux-là.
Puis, à environ 10 000 miles, j'ai commencé à entendre à nouveau un bruit inhabituel, cette fois lorsque le moteur s'était réchauffé. Je l'ai amené chez le concessionnaire pour un rappel de flexible de frein et je leur ai demandé de vérifier le bruit du moteur. "Rien d'inhabituel" a été le rapport de retour. Ne faisant pas confiance à leur compétence, j'ai commandé un nouveau tendeur, ainsi que l'outil spécial pour fixer le volant moteur en place, et j'ai remplacé le tendeur moi-même. Effectivement, l'ancien était "gelé" : aucun ressort ne fonctionnait.
Jusqu'ici, tout va bien pour le 3ème tendeur. J'ai une bonne oreille pour les bruits mécaniques (même si je ne suis pas mécanicien, je suis comptable en col blanc !) donc je me fais confiance pour repérer les bruits qui recommencent à se produire, même si c'est un pari risqué, bien sûr. Peut-être qu'un jour je prendrai la peine de passer à l'hydraulique.
Bonjour Cessie76
J'ai le même claquement après le démarrage, et j'envisage de remplacer mon tendeur hydraulique (2019)
Je serais très heureux si tu pouvais me communiquer les dimensions de l'outil de blocage de PMH
Cordialement Chris
2 years ago I had mechanical rattle come from where turned out to be the timing chain tensioner. Oblivious to the seriousness of the problem I drove on for just slightly too long - until the timing chain skipped a link on the freeway, while doing 140kms/hour on the left most lane... Fortunately no-one was injured but the engine was a total loss. I immediately purchased another c650gt and preventively replaced the tensioner with a hydraulic one - better safe than sorry on this part I would say.
