Which high-temperature grease?
emseedee
Coventry, UK
In the user's manual for my 2016 C650GT, is says that when replacing the silencer (muffler if you're on the other side of the pond), you should apply high-temperature grease around the inside of the silencer pipe. It doesn't say which high temperature grease to use. Would a copper-based grease (e.g. Copaslip or CopperEase) be appropriate? If not, what would you suggest?
Thanks
Mike
I've used this on variator splines on a few C 650 GT belt changes. I believe it's equivalent to the grease that BMW specs.
Thanks, but this isn't the grease I'm talking about. The one I need goes in the joint between the silencer (muffler) and the exhaust pipe. Its sometimes described as packing compound, but BMW refer to it as high temperature grease. I think the purpose it to stop the joint leaking, and at the same time allow it to be dismantled.
Copper anti-seize would definitely be a good choice. The grease component will carbonise over time, but the colloidal copper will remain as a sealant and also act as a lubricant to aid disassembly in the future. It is said that nickel based lubricants will withstand higher temperatures, but copper has always been effective when I’ve used it on exhaust components.
