My experience replacing the CVT belt on a BMW C400X – hopefully this helps someone
I wanted to share my recent experience in case it helps someone avoid the same problem.
My scooter is a
2022 BMW C400X with approximately
17,300 km on the odometer. I decided to perform preventive CVT maintenance and replaced the following parts:
- New Mitsuboshi CVT belt (sold as a replacement for BMW part number 24828395830)
- New genuine BMW rollers
- New genuine BMW slide pieces
During the service I also carefully inspected the entire CVT.
Everything was in excellent condition:
- the variator faces were smooth with no wear,
- the clutch bell showed no signs of overheating,
- the clutch shoes had perfectly even wear,
- all bearings rotated smoothly,
- the CVT housing was thoroughly cleaned before reassembly.
The installation was carried out
exactly according to the BMW service manual, using the specified tightening torques and procedures.
The problem
Immediately after the repair I noticed a strange
knocking/clattering noise at idle coming from the CVT.
At first I thought I had made a mistake during assembly.
I disassembled the transmission again several times and checked everything:
- roller orientation,
- slide pieces,
- torque values,
- clutch assembly,
- variator,
- bearings,
- belt alignment.
Everything appeared to be correct.
The scooter rode perfectly. There were no vibrations, no loss of performance and no abnormal behavior while riding.
The noise was only present
at idle.
Finding the cause
After removing the CVT cover again, I started the engine while observing the transmission.
I finally discovered the source of the noise.
The
inside of the Mitsuboshi belt occasionally touched the plastic guide roller located in the center of the CVT cover.
Every time the belt contacted the roller, it produced the knocking sound.
After only about
18 km, visible wear marks had already appeared on the inside of the belt.
The plastic guide roller also showed contact marks.
(Photos attached.)
Important
The original BMW belt
never produced this behavior.
I cannot say whether my belt was defective or whether this is simply a manufacturing tolerance issue.
For that reason I have returned the belt for an official warranty inspection by the importer.
My advice
I'm
not saying that all Mitsuboshi belts are bad.
Many riders use them without any issues.
I'm simply sharing what happened in my particular case.
If you replace the CVT belt on a BMW C400X, I recommend checking for this before assuming everything is fine.
If you hear a knocking or clattering noise at idle after replacing the belt:
- remove the CVT cover,
- observe the belt while the engine is idling,
- check whether the belt is contacting the plastic guide roller,
- inspect the inside of the belt for fresh wear marks.
It may save you many hours of unnecessary troubleshooting.
Conclusion
In the end, this "cheaper" aftermarket belt became much more expensive due to the extra labor, replacement hardware, shipping costs, and the possibility of replacing the damaged guide roller.
Personally, I have decided to go back to a
genuine BMW OEM belt.
I hope this information helps someone else avoid the same experience.
