SteveADV
Yeah, that is a big problem here in Chicago. I haven't been able to ride in about a month and I don't see any sign of decent weather on the horizon (40+ degrees).
That's why I live in Cleveland....for the great riding weather.
That's why I live in Cleveland....for the great riding weather.Today, for example, was a perfect day for riding. Sunny and mid-30s. At least I think it's called a sun. It was out for about an hour, but hey, to qualify for a sunny day in this town we just need a minute or two....even if it pops out only in Akron. That's close enough.
Okay, took the battery in yesterday and they told me it wasn't the battery. He actually thinks it's bad gas. I tiold him I just filled up a month ago and put some stabil in for the winter. He told me NOT to use Stabil, go figure. He said it just messes things up. Thought I should add some Marvel oil treatment to the gas rather than a fuel stabilizer. I would have never thought that?? Anyway, I just drained the gas and going to put some fresh stuff in tomorrow or Saturday and see what happens. He also said I might want to shoot a little starting fluid in the infector if the gas doesn't do the trick?? Showed me where to spray a quick shot. Don't want to do that but will try if the new gas doesn't do the trick. Of course the ether might just let it run momentarily as well. If none of this works, will have it towed at some point.
The dying battery sounds more like a symptom of a problem, not an issue with the battery itself. You've got a parasitic drain SOMEWHERE in the system. Do you have an alarm system or some other anti-theft device installed?
If you start your bike and let it idle the rpms will not be enough to charge the battery also you should let the bike get up to full temperture otherwise there will be condensation build up in the oil You would be better off taking the bike out for a ride for about 1/2 hour or so than just letting it idle in your garage. I can't do that where I live there is ice all over the place and only in the 20s in the day and lower at night. If you want to put an additive in your gas try Startron it binds with the ethanol and keeps the gas from breaking down.
Thanks to everyone who replied, I learn a lot from you guys! Anyway, I just had a chance to siphon out the old gas (a little more than a month old) and put battery back in, put a gallon of fresh fuel in and it started up. It did sputter quite a bit when I gave it some throttle (had it on the center stand). I was beginning to wonder about it, but after about 5 minutes of idling I decided to take it on a 12 mile spin. No problems so I guess it was the gas or stabil that he warned me about, don't really know?? Anyway, the only issue I noticed now is that my fuel gauge still shows full even though I have around a gallon of gas in it - it's like it didn't realize I siphoned 4 gallons out?? Hopefully that will correct itself when I fill it all the way up. I guess I will start the bike up every couple of weeks and let it idle for a while this winter to hopefully avoid that issue again. Also put it back on the CTEK tender.
Best to everyone and have a nice Christmas!!
