- Thread starter
- #21
Thanks,From my point of view and from the evidence (photos and videos), the shoulder of your tire on the rim is good.
There's just an optical effect linked to the marks/dirt on the tire. But your rear tire runs smoothly and as well as you'd expect!
Have you explored the possibility of a foreign body in the tire (e.g. mounting residue) that could be causing a random imbalance? If I were you, I'd use a static hand balancer to check your two wheels on this and other points.
Wheel axle misalignment (usually caused by impact: potholes, kerbs, front or rear impacts) can also lead to shimmy.
On the front wheel, this can be seen immediately when the wheel is turned with a workshop stand to keep the fork upright.
On the rear wheel, if the axle was misaligned, this would be immediately apparent when turning the wheel with the scooter on the center stand. Not so in your case. On the other hand, if the swingarm axle was bent, it wouldn't be noticeable under these control conditions.
For the front end, I also encourage you to check the lateral AND axial play of the steering. Also check fork tubes for tightness and evenness of tube insertion heights at the fork tees.
For the rear, I encourage you to check the swingarm axle bearings and the straightness of the axle itself.
Finally, if there's nothing else obvious, I'd check the condition of the transmission and, last but not least, the tightening torques of the frame/motor rigidity assemblies.
No news@Bojan Gjoshevski do you have any news on this. I have the same problem ?
ok thank you @Bojan Gjoshevski, hope you can solve the problem, if you solve yours i think i will solve mine too.No newsI’m still waiting on Michelin to approve the claim so i can replace the tires, but I suspect that’s not the problem. When the motorcycle is cold, I’m in NYC so temperature is around 30es, I feel swaying on very slow speed and then it gets better. I’m 99% sure the problem is in the head bearings. I’ll keep you posted.
I’ll definitely do it at the dealership but it’s not that complicated. I’d say maximum 2 hours labor. Just front left and right panels need to come off, also the handlebars cover.ok thank you @Bojan Gjoshevski, hope you can solve the problem, if you solve yours i think i will solve mine too.
I think Replacing head Bearings will be a pain in the ass because of the plastics removal![]()
I hope thats not the problemWorst case scenario could be a crack in the front part of the frame. This typically needs an xray to confirm.
When the tire was replaced, was the tire pressure sensor knocked out of place giving a false balanceHey guys, just an update. After replacing the steering head bearings the handlebars wobble is gone. The motorcycle is much more stable at higher speed. Now at very slow speed at around 5-10mph I get vibrating in the handlebars and the bike sways. The road feels bumpy even though it’s not.
I checked the rear wheel on the center stand yesterday and it looks like it goes up and down. You can even see the disc brake moving a bit.
Not sure if it could be the rear bearing.
Second set of brand new tires installed and balanced.
Ben
I have no idea.When the tire was replaced, was the tire pressure sensor knocked out of place giving a false balance
