Norman
40 x 68 x 15mm Sealed Ball Bearing (marked FAG 6008 2RSR). this is only one I replaced. The bearing place told me just to use a 6008 sealed bearing.This has been fascinating to read now, as the timing is perfect. I think I am in need of the same repair for the second time in 44k miles, last being done at the dealer. I am searching high and low for the needle bearing in the US, but seem to have no luck finding a bearing with the "ARS" designation. Do you know where I can purchase one? Also, I see these are sealed on two sides. I assume they are pre-lubed, correct? The other bearing seems readily available. Appreciate any information anyone has.
Thanks,
Patrick
The needle bearing I just greased with plenty of high temp bearing grease. The seals looked ok but I shorted the spring inside. Learnt that 50 years ago.
A bit of a Backyarder Job...bike going good now ( 51000Km)
