Never used my home plug, always use the banks free Level 2 charger which...when I forget charges the bike to 100%
Below info is from my OneNote app where I posted information about charging the CE04 battery. Hoping most of it is correct. Thinking I got most of thie info from this site.
Wait to charge when down to 20% (if you need 100% for a long trip then charge day/night before to get to 100%; do will ride it within (maybe) a week.
Leaving the scooter parked for long periods, that a very low or very high state of charge can more readily damage the battery.
Battery cooling/heating
*our scooters do not have the liquid cooling/heating for the battery like the i4/iX though it still has adequate passive cooling to handle the low rate of charging the CE04 is capable of
*our motor has active thermal management
Charging
*At either 3 or 6.6 kw, the battery will not be stressed anywhere near the level which DC fast charging creates.
*Your level 1 home charger will be only marginally gentler on the battery as compared to a level 2 charger.
*Ride down to 20% charge then recharge to 80%
*If you need 100% charge for a ride then ride it that day after it reaches 100% charge.
Battery drain
*If you drain your battery pack to a very low state of charge, but you plug it in as soon as you get back for a charge you should be ok.
Key point is did not let it sit at that low level, that woud be bad for the battery.
*If run the battery to a low state of charge infrequently, you will not significantly reduce the lifespan of your battery.
*The Battery Management System (BMS) will protect the battery when the scooter is in operation, and not let the motor drain the battery as quickly (reducing the discharge rate) when in a low state of charge, compared to a higher state of charge - like 4% versus 40%. TFT will display a message about this if it happens.
*It is when the scooter is parked for long periods, that a very low or very high state of charge can more readily damage the battery.
Other Charging Note -
Even DC fast charging, which we cannot utilize, does not always significantly reduce the lifespan of an EV's battery pack.
For example, if fast charging was an option and is used infrequently,
and the pack is not drained lower than 20%, or charged to 100%
and left sitting in that state of charge for weeks with temperature fluctuations (stressing the battery because of voltage drift),
a battery pack can still last many, many years.
The AC charging rate is significantly lower than DC fast charging; 3/6.6 kw (12kw for some vehicles like Zero bikes with the charge tank) versus 50-300+ kw.
