electrical connection for heated gear (gerbing)
Denver, CO
I added the plug in for my Gerbing heated gear to my GT, I took both fairing side covers off and connected the fused wires to the battery on the right. Then took the cover off that surrounds the ignition switch below the handle bars. I used a wire hanger straightened out with a loop on the end as a fishing tool, I put it through the left side over to the right and taped the ASE connector end to the loop.
(Taping over the looped end keeps it from snagging any wires), I pulled it across to the L side, then fished the wire from the larger hole on the right side of the left fairing pocket to the opening on the left. Once again taping the SAE connector to the wire loop, I pulled it through to the before mentioned hole, then I re-installed both side covers, and routed the SAE connector and wire to up to just below the handlebar cover, and re-installed the cover over the ignition switch. When not in use I put the connector in the left fairing pocket.
It works great, just got to remember to not turn on the heatroller or pug it in until the bike is running.
....I pulled it across to the L side, then fished the wire from the larger hole on the right side of the left fairing pocket to the opening on the left. Once again taping the SAE connector to the wire loop, I pulled it through to the before mentioned hole, then I re-installed both side covers, and routed the SAE connector and wire to up to just below the handlebar cover, and re-installed the cover over the ignition switch....
Say whaaat?? Sounds like the surgeon describing to my wife what he had to do to my knee after my last minor accident.
Pretty much what I did to my GT. Ran a wire from the battery through a 5A fuse to just below the handlebar cover and installed a 12v coax socket. I cut a slot in the handle bar cover on top of the left side near the rear edge. That allowed me to clip my Gerbings dual controller and plug it into the new socket. It's easy to reach and you can see the indicator light on the controller easily. I shortened the wire on the controller to about 6" to neaten things. Made for a nice installation no floppy wiring.
I also fabricated a cup holder by using a piece of aluminum attached to the side of a plastic cup holder. The tongue of aluminum on the side of the holder just slips nicely into the slot that I made for the Gerbings controller. Very handy.
Photos? I have wireless remote and WarmNSafe jacket liner and gloves. I usually just have SAE cable hanging to my left below seat and connect when I get on. Controller on my current motorbike I attach to handlebars
i found several coaxial panel mount adapters but all were low amperage and solder, so I went to Gerbing's web site and found their solution.
Pt#G1219U-ACC-937-001-10001 on sale for $18.74 + 5.00 shipping it evens includes a plug in wiring harness with fuse holder and fuses.
A note about coax connectors for powering heated clothing--
They are fairly easy to short when connecting the plug to the jack, which blows the fuse. It's wise to put a switch or relay or heat controller between the battery and the coax jack, and make sure the jack is not live when you insert the plug.
