First oil change on my C650GT
" ... will not ship from US to Australia if the item is available from their Australian outlet"
Sounds like a hostage negotiation. "You can have your product if you buy it our way, for more money."
Just had a similar experience shipping a GIVI top case from the U.S. to Canada. I paid UPS in advance, in full, and when the package arrived north of the border, UPS Canada told my buyer she had to pay a "handling fee." She's fighting it. Meanwhile, UPS Canada has her package. She can have it anytime -- if she pays the handling fee. Buyer told me these "oh by the way" fees are a big, ugly deal with lawsuits and investigative reports on the company.
Isn't handling a package a normal part of delivering a package? Normally I would have used the U.S. Post Office, but that's another can of worms nowadays.
Can anyone tell me which Torx wrench (size) I will need for removing the oil drains on my 2013 C650GT?
ENGINE OIL
3.1 liters MOTUL 5100 4T 15W50 Synthetic Blend, rated SL (which is higher than SJ and formulated for catalytic converters).
TORQUE Oil Drain Plug Bottom : 28 Nm (20.5 ft. lbs.). 8 mm hex
TORQUE Oil Strainer Plug Side: 15 Nm (11 ft. lbs.). 17 mm socket. REMEMBER: Insert screwdriver through strainer tube until it’s in place securely so it doesn’t fall down into the oil pan.
GASKET FOR ENGINE OIL DRAIN PLUG: BMW # 07119963252 (SAME AS GEAR OIL GASKETS)
GASKET FOR OIL SCREEN TUBE BOLT: BMW 07119906605
ENGINE OIL FILTER
BMW #: 11427673541 ($21.19)
TORQUE Oil Filter OIL FILTER (BMW or KN 164): 11 Nm (8 ft. lbs.)
I just changed oil and filter on my 2016 Sport. I removed all four drain plugs, just for good measure. The two at the bottom (hex) and the two on the sides. It's difficult to get a proper oil level reading on these bikes, you have to let the oil settle for a good amount of time after warming up the engine. The oil level sensor is also quite 'sensitive'.
ENGINE OIL
ENGINE OIL FILTER
The bottom drain bolt is not an 8mm hex, at least not on my 2020. It is six sided, so I presume a larger T-45 that I currently have. Mine just spins. Need to go find one on a Sunday at HD (Home Depot not Harley Davidson!) or a local auto place. Dang. Also not sure how much torque the last guy used (BMW dealer) but I am unable to even budge the 17mm side plug. Will try some spray 'loosener' to see if that helps. I bought this one from a fellow in Portland, OR who told me he never did anything to it, only used his dealer. And since it had only 1426 miles, I think all he had done was the initial service and oil change.
Your 2020 may be special. My 2019 drain plug has a standard, six-sided hex socket. Same as specified by webbikeworld in its tutorial, "The engine drain plug (standard 8 mm hex) uses a metal crush washer, available from the BMW dealer."
Here's the link for oil change tips: https://www.webbikeworld.com/bmw-scooter-oil-filter-change
Mine turns out to be a T-50, six sided thing a ma-gig! But I found one that worked and was able to get it loose.
