hardright
The scoot came with some tools. Really pathetic. Not even a T55 torx to remove the bolts on the rear tire.
What do you guys have in your tool kit?
... Not even a T55 torx to remove the bolts on the rear tire.
The rear wheel has T45 bolts. AFAIK, the only T55 is on the grips.
The tool kit was designed for a guy like me; little mechanical knowledge and even less ability. You can remove panels, change the battery, and add lights or whatnot I suppose, but that's probably about it. Frankly, I would not have wanted to pay for more.
What about tools to change a tire?
So in my toolkit under the seat is:
Winchester Multi-tool, Neico 1/2", 3/8", 1/4", 1/4 hex combination ratchet, 3/8" drive T15-T55 Torx sockets, 5" Vice Grips, 4" adjustable wrench, ractheting screwdriver with Torx bits in handle, T9-T40 Torx folding bits, 5" flex head 3/8" ratchet, 1.5" and 3" 3/8 extensions, Tire gages, Fuses, tire valve cores, Spare Torx bits, Tire repair tool, set of screwdriver and torx bits, hex socket extension, hex socket to 1/4" adapter, hex socket to 3/8" adapter
In the small bag on the rear rack is:
12V air compressor, tire slime, tire repair kit, bungee cords, and rainsuit.
