Torque values for wheels and brake calipers.
daseth
NL
Does anyone have the torque values for the rear and front wheel bolts, and brake caliper bolts?
Seems like it's a well guarded secured by BMW that they.avoid sharing in their manual.
daseth- A quick inquiry via Gemini produced this.
Sources for Torque Specifications
BMW Rider's Manual & Service Data: The core values for the front axle (50 Nm) and pinch bolts (19 Nm) are explicitly listed in the technical data sections of the BMW CE-04 Rider's Manual and verified by BMW service technicians in technical forums.
UKGSer & Motorrad Technical Guides: Detailed maintenance values—specifically the 60 Nm for rear wheel bolts and the 38 Nm / 24 Nm split for front and rear brake calipers—are documented in community-vetted technical data sheets that aggregate data from the BMW Workshop Information System (WIS).
Detailed Data Reference
Component Torque (Nm) Source Reference
Rear Wheel Bolts 60 Nm BMW Service Data (M10 x 1.25)
Front Axle Bolt 50 Nm BMW Service Manual (M12 x 20)
Front Caliper Bolts 38 Nm BMW Technical Specs (M10 x 65)
Rear Caliper Bolts 24 Nm BMW Technical Specs (M8 x 25)
Pinch Bolts 19 Nm BMW Rider's Manual
"The core values for the front axle (50 Nm) and pinch bolts (19 Nm) are explicitly listed in the technical data sections of the BMW CE-04 Rider's Manual" - really? I don't see that at all. https://manuals.bmw-motorrad.com/manuals/BA-Extern/IN/BA-INTERNET-COM/PDF/C_0C51_RM_0123_01.pdf
I went for 38Nm on the front caliper bolts. Seems like a lot though and I don't remember them being particularly tight when I loosened them. Would be good to see these figures in an authoritative doc.
That's because it's not in there. Which is really disappointing. They have other technical data in there, but all of that is pretty useless (unless I really need to know the brake disc diameter, but what would I need that for?).
The manual for my 1250GS is much better, torques are in there for just about anything.
