JaimeC
OR... you could just alternate hands on the brakes.
I was jsut wondering, in order to keep the safety, and had the parking brake you want (for hills); then add another cable to the parking brake line and put on a locking lever in an inconspicous place on the scooter.
you get your hill brake and retain the safety. it would be a little pricey, but at least it wouldn't be unsafe.
the other option I was thinking was a hinged wedge with thumb flip. it would drop down into the opening on a brake lever and flip up woth the thumb to release.
just a thought
A manually set hill-holding brake that is automatically released when you roll on the throttle.
Just performed the side stand kill switch eliminator mod on my 600. I feel so "unsafe", also liberated!
Really? How about if we stop counting on government regulation to extend the life of the truly ignorant (or terribly unlucky).
As for myself... I will enjoy the convenience of taking a little risk.
If I am reading the post here is the engine won't shut off (this sounds good to me) and when the stand is down the brake is applied (that sounds good to me). With this set up the bike should not fall over and you would not be able to ride off because the brake is on. I think the brake is applied mechanically. With this setup you would not have to worry about leaving the stand down and killing yourself on a left turn.
Re: Warmup. The manual says to "...Ride away immediately after starting the engine." See page 51
I did the side stand (engine shut-off elimination) modification on my bike today and I love it.
I was beginning to wonder just how long my starter was going to last since I had to restart the bike every time I got off it to open (and close) gates, garage doors, etc. This may be a little bit of an exaggeration but my guess is that the starter will last 4 times longer now.
I also do not see how this mod will cause a safety problem since the bike will not move while the side stand is down (I tried it and it will not move) Therefore you can't ride away with the stand down anyway.
Moreover, I can now warm the engine up for a few seconds while I put on my helmet and gear. I don't care what anybody says, a few seconds of warm-up prior to riding is at least moderately beneficial and even if it doesn't help longevity much it certainly isn't going to cause any damage.
Therefore, since this mod is very simple to do, I would recommend it to anyone who is annoyed with the engine kill feature when the side stand is down.
OBTW, Thanks Skutorr for placing the original post & pictures
If you use this method of shorting out the cut off switch I have a visual on this as in the earlier pictures, how can you put the plug back in as the holes are now filled and will block the plug. Is the idea to leave the wire just hanging.
Thanks this is what I thought and when I do it I will make sure it is all water tight (maybe some silicone).
What is the third pin for?
It's possible. Those of us who have had (or have...) other Maxis liked the convenience of a parking brake while stopped on hills at the light, etc. It frees up your hands for other tasks than keeping the brakes on. BMW's engineers apparently figured that enough people had bikes FALL OVER while on the side stand, due to not having the brake applied, that they made it automatic.
Good Idea! And it kills your engine...
On a brand new BMW Forum in Spain, a quick and easy mod was posted. It's inserting a bridge across the plug for the stand sensor...thinks it's always up and the engine won't die when you lower the side stand to USE the brake!
Pics:
View attachment 320View attachment 321View attachment 322
