BMW CE-04 range data as measured across 600 miles of riding
triangletom
TL;DR: Determining the maximum range of the BMW CE-04 is complicated but is fundamentally determined by your average travel speed and the weather.
This data was collected in November and December in North Carolina, and is heavily skewed toward fall and winter weather and long windy country roads (45/55mph). I only included data from rides with enough data to suggest a trend: I chose an arbitrary cut-off of 15km (9.6 mi), meaning I only have 21 rides to include. While I expect the range to improve significantly as it warms up, as of December 27th, here are my numbers:
Best range: 79.9mi (128.6km) at 53'F (12'C) with an adjusted average travel speed* of 38mph (61km/h)
Worst range: 49.5mi (80km) at 41'F (5'C) with an adjusted average travel speed* of 63mph (101km/h)
Lifetime average range:
64.5mi (104km) at 47'F (8'C) with an adjusted average travel speed* of 45mph (72km/h)
* Adjusted Average Travel Speed: My attempt to arrive algorithmically at a number that resembles the typical travelling fast on each road. This drops the first 10% and final 10% of data points to avoid including parking lots and pulling into my neighborhood, and any speeds under 20mph, as these are significantly slower than my local speed limits, and thus reflect deceleration for stops signs and turns. For example, most of the roads for my "worst" example (62mph) had a 65mph speed limit, but some were 45mph and 70mph.
Realistically in North Carolina, you can depend on a range of 75 mi if you are predominantly travelling on city roads or 45mi if you are hugging 70mph highways. My travel is mostly a mix of 35mph/45mph/55mph two-lane roads, which is why I get 65 mi:
There is a huge "down and to the right" trend. You can see it a little more clearly with this graphic:
I have to collect more data toward both speed extremes, but you can see a trend here that your average speed has a huge impact on range. Mode selection does not have as much of an impact on the range as I had initially suspected: if you are using regen to coast to a stop instead of using the brakes, it doesn't matter what mode you've selected, although Dynamic does make me feel like a hooligan on the road.
I did a bit of research on power consumption for speed, and it seems to follow this formula:
power consumption = 0.5 * density_of_air * velocity^3 * drag coefficient * surface area
The power consumption required to overcome wind resistance has a cubic relationship with velocity. You don't notice this as much in an ICE vehicle because it's consuming fuel even when it's not moving. While I haven't seen a drag coefficient number published for the BMW CE04, I'm willing to bet the CE 04 drag coefficient is not stellar.
One thing I've found very surprising is how much weather impacts the maximum range of the BMW CE-04. In a nutshell, my observations so far suggest:
- Rain can result in up to a 10% range reduction
- Freezing temperatures can result in a 33% range reduction (comparing performance between 20'F and 68'F).
Here is what I have so far for range vs temperature:
There is a pretty clear "up and to the right" trend. With more data, I expect this to become more of a curve, with a steeper drop-off appearing near the freezing temperature range, and leveling-off around 70'F. If it helps to see a trend graph, check out this one:
In closing, I feel like most BMW CE 04 owners in the US can safely rely on a range of about 62 miles (100km), unless they live in cities, where they are more likely to see a range of 72 mi (115km). If you are riding in freezing temperatures (which few Americans seem to), cut those numbers by 1/3rd.
You may notice that there isn't a lot of data for rides above 60mph: I don't live near those sorts of roads, and in general don't find >60mph highways to be relaxing. That said, I have one sample so far which included riding up to 71.5mph (115km/h) on I-540. I didn't love the BMW CE 04 in that environment, at least not when compared against a GS. I'm not sure if this is due to the wheel size or the aerodynamics. I still endeavor to collect more data across a wider selection of situations.
For those of you who want to see the raw data and come to your own conclusions: https://docs.google.com/spreadsheets/d/1l68NlBvK7G-YCM0eEJhHALTxE-_L65FxzcsRL3CHbXo/edit#gid=0
I'll post updated graphs once I reach 1000mi (1600km).
@triangletom :
I found your report entertaining and enlightening. I don't even have a CE-04, nor am I contemplating buying one, but that's the kind of information that will be useful to current and prospective owners. Well done.
Oh, by the way, I'm guessing that you're keeping the tire pressures up to spec, as you ride in frigid weather, correct? I ask, because it seems to me that that could be another factor involved in a discussion of range. (Does the CE-04 come with a TPMS, unlike, grrr, my C 400 GT?)
triangletom
Thankfully, BMW saw fit to equip the CE 04 with TPMS! It seems bizarre that since 2006, the law in the United States has required every car and truck to be equipped with TPMS, but there doesn't seem to be any such requirement for two-wheeled vehicles.
I've had the bike for only seven weeks so I haven't had to do much in the way of pressure adjustment, except for once after the initial ride home from the dealer. I understand that tire pressure varies significantly with temperature, but haven't seen any warnings since. I'll be sure to take a look tomorrow to see how far off spec I am when I go out riding.
If you park the bike in your bedroom or living room -- to admire it, secure it, and keep it warm -- and you want to set the pressures appropriate for the chilly ride before taking it out of the house, you may find a calculator page I put up on my web site useful:
BTW, it really irks me that BMW did a double whammy on C 400 GT owners: 1) no standard or optional TPMS, and; 2) putting the valve stems sideways in a spoke prevents adding an aftermarket sensor to the front wheel (and I did add one to the rear wheel, where it's possible, because of only one brake caliper). If the bike weren't so good in most other respects, I would constantly dwell on that.
lt_fukai
This is some excellent data. I'm in a different position in regards to speed: all roads around me in California that lead anywhere worth going are either 65+ highways or roads where local traffic pushes the speed that high. I've quite enjoyed mine at high speeds, but it is painful to know I'm always on the low end. It feels like I get 40 miles. I wouldn't mind contributing data, how did you test this, did you go full-to-empty or is it based on distance and charge used?
MKUNES
Interesting Data. I got my CE-04 last Thursday. Yesterday we visited my son in Northampton 38 miles away and used 6.4 kWh - so thats 5.9 miles per kWh. Not very good really. I had the heating off and the running lights off. I also have a Kia e-Niro and have achieved 5 miles per kWh for the same journey although just over 4 is more usual. Temperature was about 50 F and bike in road mode.
Incidently my son has a Nissan Leaf which has a type 1 charge port so I bought an Adapter off Amazon - his charger worked well and filled it up in just over an hour (from 44%) using the 30 A setting .
Update - my son had a go on it while I was there and did 3.8 miles so my total jouney after charging was 41.8 miles giving 6.5 miles per kWh not 5.9 as I stated above
Further update. - have just found that you get a direct readout of the efficiecy - mine says 9.1 kWh per 100 km so thats 0.091 kWh per km or 6.9 miles per kWh - not brilliant - would have thought it would be at least double the car's figue.
