JBChucktown
How can I find the correct tool list to remove the variator, especially the one that locks the two pullies together so you can remove the lock nuts.
Thanks for your help!
I created a guide for this service if you haven't already seen it.Awesome! Thank you for the great info! I will search for everything tonight. I will keep you updated on the results.
Excellent work, thank you! This will definitely give me more confidence to tackle the job. The belt only has 4800 miles. Hopefully it doesn’t need changing.I created a guide for this service if you haven't already seen it.
BMW C650 GT Belt and Roller Service (v2).pdf
drive.google.com
I am noticing some noise that may be the timing chain tensioner, I know this won’t help that but it is something I can do to help eliminate possible noice causing options.
David,
That guide is excellent. Greatly appreciate your generosity in compiling and sharing it.
Thank you for the addition. I received Multivar today in the mail but waiting on a few other parts before I get started.
is there a recommendation of how much to put in there? I know there is usually a line between to much and not enough but either one of those can be bad.
Also, should I plan to go ahead and switch out the rollers that came from Malossi with the Multivar and put in Dr Pulley sliders? Thanks for the advice!
Thanks and for responding! Maybe last question. The kit came with roller sizes 24 and 22. I will probably use the 24( touring), should I order that same size? The Dr. pulley website recommends 28 g for the stock variator which is currently in there. How will I know which size and weight To order for the Mallossi variator if I can’t use do you guide? I know the weight but not sure of the size. Thanks for any advice you have!
No, I have the stock variator. The only enhancement I’ve made in that area is with the sliders and sliding pieces. Everything else has been returned to stock.Great! Thanks. Do you have the Malossi Multivar variator?
Anyone know a good substitute for the Unirex N3 grease?
Actually, I was wrong! I ordered mine from A&S and had it within a week.I ordered it too but I guess it is on backorder....
That's odd. A&S is usually really quick. I'm in Florida.
