Why, oh why, would BMW replace entire ENGINES or BIKES when the timing chain tensioners fail and bend valves? Because the PARTS to fix it are NOT AVAILABLE!
That's right! I went to the link Jaime just posted for those OEM deflectors, and the BMW Parts Microfiche is available on that Dealer's Website. COOL! So, being NOSEY, I poked around...
Prices:
1.) variator rollers...$145.06! (get Dr. Pulleys!!!)
2.) clutch...$347.18! (HIT Clutch is about the same...and WORKS...)
3.) variator belt...$233.08! REALLY! It's TAIWANESE! Someone track the supplier down and get it CHEAP or go Aftermarket...
4.) front brake pads...$68.30/caliper OUCH! Brembo, Galfer, Malossi, EBC are all much less. EBC is about HALF the price and much better!
5.) front rotor $228.97! Go WAVE, or an OVERSIZED kit for the same $$$
6.) timing chain tensioner...(that kills engines...) $53.72. THAT"S IT??? Change it! Carry a SPARE!
And here is the WEIRD part:
NO brake front calipers or the repair kits for them are available, NOTHING.
NO exhaust valves are available...only intake. Better just bend an intake valve...
NO Cylinder heads are available. NONE.
So, you bend an exhaust valve, you replace the ENGINE or ENTIRE SCOOTER. That's INSANE!!! But, it finally explains the long delays at the dealerships, who probably can't BELIEVE there are NO PARTS, and the wholesale replacement of engines and/or scooters. If a caliper leaks you also get a new bike???
Gotta be the worst Business Plan I've ever encountered...
Prices:
