toomuchvinyl
I did a quick search on the forum to see if I could find any earlier postings regarding this and didn't so hopefully I'm not reviving something that has already been discussed.
Now that the weather is getting cooler I have noticed that on my ride in to work in the mornings my ambient temperature display never shows a reading below 50 degrees Fahrenheit though thermometer temps at both my home and work are showing mid to low 40's. I noticed after my first service/inspection that the pre-ride check that happens when the key is turned on was a bit different, all characters on the display are lit and the warning symbol indicating the check is in progress goes off much quicker that it did prior to taking it in. Also my headlight doesn't come on until the motor is actually started. Since I took delivery in May, the temperature displayed had always looked correct though it never had to register on the cooler side of things.
My question is; Has anyone had issues with the air temp accuracy and do you think that the issue is software related or a problem with the sensor?
