Redditch
Yesterday I took possession of my C600 Sport (2012) and I have read the manual but I cannot find the answer to why the dashboard has the 'SERVICE' indicator on all the time.
"If the next service is due in less than one month, the date for the next service 1 is shown briefly after the Pre-Ride Check completes" - Not relevant as it does not go off, its always on.
"If the vehicle covers long distances in the course of the year, under certain circumstances it might be necessary to have it serviced at a date in advance of the forecast due date. If the countdown distance to the odometer reading at which a service will be due is less than 1000 km, the distance is counted down insteps of 100 km" - I take this to mean that if you have done more miles than expected the system counts down to let you know it needs a service - reasons this cannot be correct are A) It has just had a service. B) The dash does not show a mileage countdown figure (it just shows the total mileage).
"If service is overdue, the due date or the odometer reading at which service was due is accompanied by the 'general' warning light showing yellow. The word "Service" remains permanently visible." - Again not relevant as the yellow warning light is NOT on (the warning light does work on the visual check on start up)
"If the service-due indicator appears more than a month before the service date, the date saved in the instrument cluster must be adjusted. This situation can occur if the battery was disconnected." - I am left with only this option, where I can only guess that after its service something was not done correctly and the bike is confused (bless). But I do not know how to alter the next service date.
So I think my question should be "HOW DO I ALTER THE NEXT SERVICE DATE" and how long should it be set for ??
Thank you
Thank you
