RollaCosta
Do you think the motor is varying the angle, without ECU command, then?
You will always get lambda code if engine stalls. I keep my fingers crossed you will fix the problem. I have done 3k km since ista+ adaptations, still working like newLet me add to this thread and confirm that, indeed, cracked idle air contol valve hoses do cause stalling at idle.
Yesterday, for the first time in about maybe a month, I rode my C650 Sport to the gym, a 16 mile ride each way.
To my surprise, at the first stop sign I encountered, after about 10 miles, the engine cut out. I restarted it without issue, and it did not happen again for the remaining 6 miles. However, when I went to ride back home after my workout, it stalled at the very next traffic light, less than a mile. It then stalled at the next light after that, and the next one after that, and so on. Sometime it would 'struggle' to keep running, but would inevitably stall. Each time it would restart without any problem, however I would have about a second to launch the bike, or it would again stall. The last 10 miles were without any traffic lights or stop signs, and to my somewhat surprise, it did not stall when I got home and parked the bike. Still, obviously an issue.
Scanned the codes and I got 'Lambda sensor 01' fault code no 3A2020 on the Motoscan. I went ahead and ordered a NOS O2 sensor (part no 11787716654) after taking out and verifying the original one. But then I reread this thread and decided to also inspect the vacuum/air lines going to the idle air control valve. I had done so once before, in around 2023, and found one beginning to crack. I replaced that one, but the other one looked in ok shape. Well, today that other one is VERY cracked!
Luckily, in 2023 I had bought 2 new ones, so I was able to install the new one right away.
I will still also install the new O2 sensor (can't hurt and the NOS one was only $70 as opposed to BMW's current friendly price of $450) and also install one of my 4 new mechanical timing chain tensioners. The current one (3rd one since new, the bike has 20K miles now) started to every once in a while make a faint death rattle so I figure now's the time. I bought 4 when that batch came up on Ebay for (as I recall something like) $110, so "cheap insurance" on that other common and massive problem plaguing these otherwise wonderful machines.
Will report back when I have it all back together but I am 99% confident the new idle air hose will fix the stalling issue.
