jeffspinks
I am trying to properly diagnose and fix a no start issue with my friend's 2013 BMW C650GT. I have replaced the battery and the new battery tests 12.64 volts with my digital multi meter. The dash lights-up when I turn the key on but when I push the start button with the kickstands up there is no response. I listened for the fuel pump to power-up but nothing happens with that either. I am thinking that the side kickstand switch could have gone bad. There's 3 wires leading to this side kickstand kill-switch and 2 are reading 5 volts and the third wire reads 10 millivolts (Key On Engine Off), so I think it's getting the signal and proper voltage. I removed the side kickstand kill-swith and tested it with my digital multi meter set to read ohms and all 3 metal prongs on it read OL, which I've been taught means Infinite Resistance. With the KOEO the 2 wires in the wiring harness connector read OL but the 3rd wire reads 33 ohms and my meter produces an audible beeping sound. What does this beeping sound mean?
